- Social||Forum, leaderboard, users
- Forum
- International Section
- Do it Yourself
- DIY autopilot GoPro Drone - RC Multicopter Buldlog
Do it Yourself projects - everything you made / modified / invented by yourself.
9 years 3 months ago - 9 years 3 months ago #14
by Stuyo
Stuyo replied the topic: DIY autopilot GoPro Drone - RC Multicopter Buldlog
Quanum Trifecta Frame assembly + Baby Beast motor mounting + Afro ESC mounting and testfit:
Resources:
1. Baby Beast outrunner - Multistar V2 2206-2150KV Motor The "Baby Beast" (V2)
2. Afro ESC 12A - Afro ESC 12Amp Ultra Lite Multi-rotor Motor Speed Controller (SimonK Firmware) Version 3
3. MG Servo - Turnigy TGY-9018MG Metal Gear Servo 2.5kg/13g/0.10
Resources:
Last Edit: 9 years 3 months ago by Stuyo.
Please Log in to join the conversation.
9 years 3 months ago - 9 years 3 months ago #15
by Stuyo
HKPilot Micro PDB - Power distribution module, cable routing:
Micro HKPilot Mega PDB, BEC and Volt/AMP Sensor 30.5mm Mounting
9 years 3 months ago - 9 years 3 months ago #16
by Stuyo
HKPilot Mega Micro controller Arducopter board put in a modified CC3D plastic HK case - cut wit saw, sanded and cutouts with exacto knife:
Resources:
1. HKPilot Mega Micro APM - Micro HKPilot Mega Micro Sized Flight Controller and Autopilot with Leads 2.7.2 (APM)
2. CC3D plastic case - Openpilot CC3D Flight Controller Protective Case
Resources:
9 years 3 months ago - 9 years 3 months ago #17
by Stuyo
The GPS module is not direct so i had to cut a piece of 2mm soft plastic.
First, cut 25mm square hole for the GPS body, then cut outside and drill holes for mounting:
Resources:
Micro HKPilot GPS And Compass u-Blox NEO-6 and HMC5883
Resources:
9 years 3 months ago - 9 years 3 months ago #19
by Stuyo
Controller installation, GPS, Telemetry and telemetry protection cover:
Resources:
Micro HKPilot Telemetry radio Set With Integrated PCB Antenna 433Mhz
Resources:
- Forum
- Do it Yourself
Time to create page: 1.027 seconds
